TuneFUSION        { Help Index   >   M4A FDK (AAC) Encoder }
This M4A Encoder creates M4A files encoded with AAC, which unlike Apple Lossless is a lossy encoder.
Compression Options
Encoding can either be constant bitrate (CBR), or quality based Variable bitrate.
If choosing VBR, then only standard sample rates, LC encoding and channels are supported.
For bitrates below 48kbps HE v2 profile is used, below 96kbps HE is used. LC profile for all other birates.
On the advanced page, the profile can be chosen, and gapless signalled specified, unless have a specific reason leave as iTunSMPB for maximum compatibility with Apple products..
Terminology
Back To Main Index
